CNCxPRO V5が勝手に再起動する
Hi Nyaru,
Glad we got homing sorted out.
When loading new firmware using the above method, the user settings will remain on the xPRO V5. However, if you issue a $RST=* command, the user settings will be updated to the defaults in the NEW firmware.
So, if you load new firmware and things are behaving strangely, it is recommended to issue a $RST=* command to get the latest defaults, then set your specific settings such as limits, homing, probes, and step/mm. This will really only be needed if we have to change hardware related settings like step_pulse time and we will note it on the firmware release details.
